Well I went and fiddled with it some more. It works a lot better with the timing advanced moderately. The timing marks were pointed directlly line to line. When the timing plate was rotated clockwise (more retarded, right?) the idle would slow and it would die. I moved it counterclockwise so that the right side of the timingplate mark was just past the left side of the housing mark. Also honda says points should be 12-14 thousandths but mine seems to work better at about 16 . Strangely enough it seems a little lean now but I haven't ridden it yet. Stock 110 carb jetting seems like it sould be within the ballpark of a piped 90.
Do you 90 guys have similar timing and points settings? Also, how many turns out do you run the air screw? It is 1.75 turns out right now.
The point arc sometimes too, is this normal?
73 & 76 ATC 70
79 ATC 90
84 ATC 110
86 200x
82 IT 175
84 CR 250
02 200 EXC
02 Blaster
