Results 1 to 8 of 8
Thread: What are these????
    Jul 2008
    Arkansas
    133
    What are these????
    Today i pulled my Big Red out of the garage to degrease the engine and i found a bolt missing on top of the engine, and the other won't tighten down. It looks like they tried to seal around it with silicone. The end of the bolt looks like it may be broken off. I included a pic of the bolt. What are these and what kinda work will be needed to fix it?
    IMG]http://i136.photobucket.com/albums/q169/arkyhunter/Aug04457.jpg[/IMG]
    IMG]http://i136.photobucket.com/albums/q169/arkyhunter/Aug04456.jpg[/IMG]
    I'm at my wits end with this thing....I'm starting to wonder if it might not be better just to try to find a running Big Red and use this one for parts. I'm still getting no spark. I ordered a new coil but haven't recieved it yet.
    Jul 2008
    Arkansas
    133
    Let me try to post the photos again:
    [IMG]IMG]http://i136.photobucket.com/albums/q169/arkyhunter/Aug04457.jpg[/IMG][/IMG]
    [IMG][/IMG]
    Jul 2008
    Arkansas
    133
    [IMG][/IMG]
    looks like valve cover bolts to me. If you take the valve cover off you might be able to extract the broken bolts easily. It might be a pain if they're broken off flush, though. If the trike's in decent shape, I wouldn't let this get to me.
    PA
    3,515
    those 2 bolts are right at the small bearing area of the cam and are importent
    but with stock valve springs it should be ok.....i would take off the valve cover and see whats going on.
    even if you only get the one thats missing in if it was mine i would sleep better.
    WWW.HREATV.COM
    Jul 2008
    Arkansas
    133
    I took the front valve cover off and looked inside- the best i can tell these two bolts hold part of the casing together. So if i want to take the entire valve casing off that means taking the whole engine loose from the frame? I've never done it before so i guess i'd better take it to someone who knows what they're doing. I know a guy that works on these and ATV's, i guess i could get him to take a look.
    All i can see right now is $$$$ flying away!
    yep, that's how it goes.
    PA
    3,515
    the thing you call a valve case is the valve cover......at least thats how its known
    the little covers are to check valve clearence
    WWW.HREATV.COM
