Thread: 85 to 86 350x frame
    Hampton, Virginia, C.S.A.
    2,664
    85 to 86 350x frame
    hey guys just trying to make sure all 85 350x parts fit a 86 frame...i may be getting one for my 85 with a broken frame ...thanks for any help
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    PA
    3,515
    the 86 frame is basicly the same as far as throwing all your stuff on it
    WWW.HREATV.COM
    Pa.'s Highest City
    8,058
    I think I read somewhere that one of the top motor mount bolts are a diffrent diameter. but I didnt run into any problems. then again.. I used a bolt kit from thefasterguy.
    Back in Happy Valley
    833
    Yes the 86 frames have all of the bolts in the top/front motor mount the same 10mm size, and on the 85's the frame has 8mm sleeves and the motor is still 10mm. It will work if you dont want to drill the mounts out with the smaller bolts. Other than that the grab bar mounts differently and everything else should line up and fit 100% until you get into barrowing rear brake parts and carriers, TC...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    2,664
    so i will just need two 10 mm bolts?
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
