I have been noticing that the good ol trust BR250 seems to be heating up more than normal ..... Yes it is around 75 degrees out side but,,, it still seems more than normal
What do i need to do in order to correct this ??
The front fender , the skirt & the front tire seems to block air movement to the cooling fins .......... What can you do when the tire alone blocks alot of air by itself ?
Is the timing off ??? It starts & runs fine however........
If you can Email me - That would be great because i do not frequent this forum that often ................. Thanks , BOB_T
