Thread: 200 auto X
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    200 auto X
    I'm in the process of putting a '84 200s motor into an '85 200x roller. Firstly i only have the mounting brackets for the 200s, which ive found are different to the 'x' frame, this isn't too much of a problem as i can fabricate some bits at work. what's really got me stumped is the wiring, the CDI from the 200s plugs right into the 200x harness, and the 2 blue and green wires from the pulser sensor match up, what i'm not so sure about is where to plug the 3 wires (red&black, green, yellow) from the motor to the 2 remaining wires on the 'x' harness? (mauve&black, yellow) Now i'm all confused
    Anyone done this before? or got a 200x wiring diagram?
    And is there any other advice for this little project?
    Aug 2006
    Arlington, Wa
    1,027
    if you search 200 auto X there is a sweet article.
    the s wires are yel, grn, and red/blk
    hook yel to yel
    blk/red to blk/red (you will need to splice in a piece of wire for these due to being short)
    the green wire then get grounded to the engine case
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Aug 2006
    Arlington, Wa
    1,027
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Jan 2008
    Kent UK
    311
    Brilliant! just what i needed! thanks for the rapid help
    Oct 2007
    SouthShore - MA
    653
    Thats a good article to save right there.
    Thanks!
