Thread: a few 200x questions
    Apr 2003
    42
    hi
    1. i havew 18 in holeshot tires, what is the best sprocket set up for these on my 200x.
    2. my whole shot tires say 18x11-10. does the 11-10 mean the width? like the acceptable rim it will take? i know there 18 tall. any one know?
    3. i bought this trikeand apparently its been bored. the piston that came with it is in good shape and it says 1mm on the top. does that mean its bored over 1mm?
    4. where can i get a set of rings online for a good price
    ok if any one knows what i am talking about and can help
    thanx
    Apr 2003
    42
    sry
    one more
    5. is there any tank scoop fins that i can put on the stock tank that flare out more or are cooler than the little ones that come stock?
    Aug 2002
    332
    For the tires, the 18x11-10 mean 18in diameter, by 11 in wide, by a 10in diameter rim. The width of the rim is not specified by the tire, but in general you would run 2-3 inches narrower on the rim width than the tire width. So, a 11in wide tire would run a 8-9in wide rim.
    I am almost positive that the "1 mm" on the piston denotes an overbore dimension.
    You can try service honda (www.servicehonda.com) for a set of rings, or partsfish.com, but you are going to have to pay shipping. Also, don't forget to get larger rings than stock. You should also be able to drive to your local dealer and buy them right there.
    You may want to try and find some suiper scoops by Maier. They were made for the 350X, and may be available for the 200X. I am not sure if they still make them, but search online and you might find out.
    I ran 18" turf tamers on my 200X and it did fine with a 1 tooth larger front sprocket. You may want to raise your front gear by 1 tooth, but leave it alone otherwise.
    Joel Morris
    Purdue University Graduate Student
    Mechanical Engineering Technology
    1985 ATC70
    web.ics.purdue.edu/~jsmorris
    Apr 2003
    42
    thanx man
    Sep 2009
    Alden NY
    3
    Yo Chaseman, were those the stock hubs on them 10" rims?
    Jul 2006
    western ny
    3,366
    when i had my 3mm over engine i always went threw denniskirk.com . . and yes 1mm means its bored 1mm .. i see your in western ny as well . down here in springville we have a ok place to order parts too . its rite on 39 . called vintage cycle. if anyone can find what you want its them . plus thier floor display of old trikes is a nice sight to see as well .
    GIT IT RAAAGGGGG !!!!
