Results 1 to 15 of 24
Thread: Thank you, ethanol! WTF???
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    I would like to thank the ethanol now put in gasoline for RUINING my lawn tractor. It slowly built a clog in the fuel system (lines, regulator, filter, etc.-unbeknownst to me) causing my tractor to run really lean ( how it ran so well I am amazed- but it's a Briggs) and eventually burn a valve. When digging though trying to figure out what went wrong, I noticed the fuel lines, tank, and other components of the fuel system had a gel-like substance in them, which restricted flow. Thanks to the ethanol eating at the rubber and plastic.
    The more I tell this story , the more people I find with lawn equipment, boat motors, etc, with trashed carb seals and other fuel feed problems due to this GARBAGE added to gasoline.
    Anyone else in this hell?????
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    it also absorbs water, and in extreme cases i have seen it ruin new car's injectors due to the water.
    Columbia
    5,131
    On my lawn tractor, at an idle it started surging, I was told by a good lawn mechanic that the pilot jets get clogged, and they do that. Maybe its related?
    THat really sucks man. Sorry to hear.
    Central FL USA
    1,174
    Thanks- I'll take any and all suggestions. I am still in SHOCK!!!!
    Pennsylvannia
    1,147
    I have heard multiple horror stories from friends about their parents expensive boats and also cars that have been messed up due to the new ethanol.
    Personally, I used gas with ethanol in it (without knowing it, for a little while) and my car now no longer runs correctly. I switched to a different gas, but it still doesn't run like it used to.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    Quote Originally Posted by nouseforaname90 View Post
    dump a few cans of SEAFOAM fuel system cleaner in your tank. the stuff works wonders.
    Aug 2004
    Ab Canada
    4,368
    We tell customers, Ethanol is ok to run, but for storage (like it sounds) it will gel and gunk the whole system up, i myself don't run it period, Thats on bikes Imo
    1985 Tri-Z-
    NE Arkansas
    2,344
    Where can you get gas without Ethanol?! Every station I stop at say "up to 10% Ethanol" in their gas.
    My Rags
    Mar 2005
    overton, PA
    5,257
    its just gay i ahve 2 mowers and 4 chain saws that are gettign fucke dup because of this crap and dont even get me started what happens to aluminum when ethanol i slef tin the carb or in aluminum parts can u say corosive.
    Trouble is offline At The Back Of The Pack Arm chair racerFirst time rider
    Tony,WI
    170
    Yup,*Edited**Edited**Edited**Edited**Edited**Edite d**Edited* ethanol is killing every thing
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    I have a suggestion, switch everything over to diesel.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    PA
    3,515
    diesel?!?!
    no way....lol
    i always gas up at the same station for my big block bronco....well one day i gave another station a chance and about 10 miles later it started running bad.....real bad.
    got it home and the fule filter was FULL of the mechanical fule pump diaphram.....so i throw a new one on ( the bad one was only a few years old) it makes noise......im like WTF!
    dump in my old faithful gas and boom....no noise to this day
    im 100% sure that corn had a roll in my problem
    WWW.HREATV.COM
    N.E. Ohio
    2,005
    I run a fuel conditioner and have been treating my gas with a Military Spec conditioner for years.
    Central FL USA
    1,174
    Well, that motor is trash in my tractor. Burned valve for sure.
    Just watch your outboards and vintage/classic stuff, guys. This sheet is killing everything.
    Apr 2008
    NW, IND.
    842
    Quote Originally Posted by 300rman View Post
    +1 Seafoam. My boatmotor floats stuck and flooded the motor. Drained all the fuellines, tank and motor. Pink crystals in bowl from ethenol crystlizing the Stabile from earlier this spring! Used 1 can of seafoam W/ 15gal. of premium. ALLS GOOD....BEETS
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
