Results 1 to 8 of 8
Thread: 350x head cover
    350xrider911 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    porter texas
    301
    350x head cover
    the cam cover is leaking what do i put on it to stop.
    bad350's Avatar
    bad350 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    kentucky
    176
    take the rocker box off, go to your local honda yamaha shop and get either hondabond, yamabond, or three-bond. these products are all the same but work much better than rtv sealant honda actually uses it on most of their center cases etc now instead of gaskets
    Nov 2007
    porter texas
    301
    ok thanks. i put rtv seal, and and its ok. buts still leaks whats the heat rating for them. cuz i put some atv seal on it and it started to boil.
    bad350's Avatar
    May 2008
    kentucky
    176
    what is atv seal? are you just smearing it on the outside or taking it apart and applying between the rocker box and head? not much will stop the leak by just putting it on the outside
    Lancaster, PA
    1,738
    Use Hondabond, I like it better them Yamabond. It needs to be a semi drying sealant unlike RTV.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    When you take that cover off, make sure it and the head are free of high spots or scrapes. I like to use an oil stone with WD40 and I rarely have another leak when doing that and using three-bond.
    PA
    3,515
    just be careful if you do this..... just a few rubs on a surface stone is fine but dont go crazy or the cam will get tight.
    WWW.HREATV.COM
    Quote Originally Posted by SWIGIN View Post
    just be careful if you do this..... just a few rubs on a surface stone if fine but dont go crazy or the cam will get tight.
    Good point! I should be a bit more specific before people start grabbing an 8x11 sheet of 120 grit paper and having at it That would surely crunch the cam riding journals.
    My oil stone of choice is a triangular stone with a 5/6 wide surface about 1.5"s long. If you run it along the sealing surface, it's very easy to see all the high spots and watch them disappear and the WD40 keeps things moving well.
    This is why DEEPA calls me STONE
