Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Welding a shifter?
    Jun 2003
    Anchorage/Homer, Alaska
    480
    Quote Originally Posted by hadar View Post
    I would replace the shaft. Your just making more work for yourself or the next owner. Most of the welded shifters I've seen leak oil out of the seal because of the heat from welding. somebody did it to my one of my kxt motors and I had to cut the shaft with a hack saw. It took longer to do that then replacing the shaft. The best part about fixing it right is that you know that it's fixed right. My $0.02, but do what you want.
    Doh'! This is the correct answer!
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Jonpin's Avatar
    Jonpin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Melbourne Florida
    333
    idk probly more work than its worth but you could try to put a key way on it tighten the $@$@#% out of it
    Funny hearing all the things that make people peed off and wonder what was going through this guys head when he did this and it makes more work for you
    05 Kingquad 700 85 200x 85 250es 85 350x
    85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
    Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
    WaimakRydah's Avatar
    WaimakRydah is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    New Zealand
    421
    The shifter off my 2 wheeler works and shifts. Now im going to get it off and chop the end of it of and weld the new end to the original shaft. The 2 wheelers shifter wont clear the recoil starter unless i have it vertically which Ive had recently. My shaft could be better but as long as it works Im not bothered.
    1985 Honda ATC200S
    1994 Kawasaki Eliminator EL250
