Hi guys a just bought a 1984 Tri-Moto 200 and it seemed like the clutch was bad sp I a justed the Nut and flathead screw on the side of the crankcase and messed everything up. So i took it apart and found that the mechanism in there had broke so i took the mechanism out it figured it to be all good. But that was a bad idea. Would the breakage of this mechanism not allow it to be in neutral when you hold the shifter up because that is what happened once i removed all the broken parts. I put every thing back together right just i guess that part needs to be in the case huh? Man im kicking my self for touching that screw.
