you just have to soften that o ring up maby put some brake fluid around the o ring to eat it away probly wont work though idk
05 Kingquad 70085 200x
85 250es
85 350x
85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
DC and Huntingfor1 i am a little confused here with what that means?
The cap has an Oring under it that is bad to stick to the cap itself and the gearcase. I have used chisels to "chip" off the outer edge of the cap where the Oring is stuck. Most of the time the cap will come on off before you get finished with knocking the outer edge of it off.
ok this is the best way i can explain what hes talking about "with pics"
heres is what the bottom looks like with the O ring
and heres the top mine is broken so you can see the area hes telling you to chistle away its to reliev the bond of the O ring ,in the end you will need a new cap for sure so this is a last resort method i would say "or just to prove a point to that *Edited**Edited**Edited**Edited**Edited**Edited**E dited* cap whos boss"
"couldnt resist digging that old cap up befor bed and taking pics and hosting them to help some one out" your welcome![]()
85 250es
85 350x
Thanks Jonpin. I was going to do the same thing but I couldn't find the one I had to post pictures of.
Hey guys,
I think i understand what you guys are saying but it sounds like your saying to chisel the head and o-ring area off but i would be reluctant to do that for fear of damaging the threads in the gearbox?? If you guys think nothing of this then i will go ahead but i wanted to double check and make sure. Also would an easy out work? Never thought of that before.
Jopin- thanks for the pics!! they ALWAYS help in a situation
Jim
The threads are in the gearbox so you shouldn't be close to them. Don't chisel the plug shraight on the top side but instead chisel it on the outer edge at an angle like in the picture below and chisel it like you are trying to unscrew the plug. Be sure you have a sharp chisel and don't use the biggestyou can find. Take your time with it and make sure your chisel isn't hitting the gearbox housing and you should have no problems. You will know you are deep enough on the edge when you can see the Oring. Once you can see the Oring enough to grab it with something you can try pulling it out and the plug may turn loose then. If it doesn't, keep chiseling the corner edge of the plug off. The plug will probably turn loose before you get finished chiseling all the way around it. Something else to watch out for is the little peices of metal that you chisel or break off. Be sure to keep the area around the plug clear of them before you take it out or they could fall into the gearcase.
I use an air chisel on a lot of stuck bolts, and it works 99% of the time. Don't go hog wild, and it will work loose in a few seconds.
smvorndran
So... you're perturbed that my example of a tool to use is from a manufacturer that has a reputation for high quality? I used their website becuase it was easy to locate the tool and had a clear picture of it. I didn't tell anyone they had to buy Snap-on, I also said Sears has the same thing. When it comes to tools I'm not brand loyal; I've used a log to knock my suspension back into place before. I don't mean to sound angry; I'm really only confused by your run on sentence.![]()
Now for something more useful,
Use a grinder (or even a file since it's Aluminum) to make a notch in the side of the cap. That will give a good spot to set a chisel if you'reing on the cap to turn it.
1985 ATC 250ES, Big Red
1984 ATC 125M's, 1.5 of 'em
1983 ATC 110, BLUE!
1974 ATC 70 Pink?
i wasnt perturbed in any way about your example of a tool i just thought my statment was funny sry you didnt and as for the run on sentence heres another one I love Snap-On just cant realy afford it i dont know if its just a mental thing but everything seems to go better when you use there high quality tools and I had to throw my lil story of my misfortune in there because im reminded about it every time i think about Snap-On and this will conclude my run on sentence .
85 250es
85 350x
Thanks so much guys! I am going to try it out tomorow and we'll see how it goes. If that fails i might try to square the bolt off and see if i can then get a wrench on it. I will post later tomorow with my hopeful results.
Jim
Did you have any luck?
didnt try it yet. farm work has prevented me from doing anything. barely have time to change my underwear ha! Hopefully soon though. would the dealer have a new cap for me...since i plan on destroyin the old one?
Jim
p.s. thanks for the follow up
