Thread: CDI interchange ability
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    Ok so on dratv they sell a cdi that is the square type connector. They say it will work with more newer models with the use of the male connector. Ok so I have a few hondas that have CDI's that work but their connectors are all square excpet for the 200s which is round. So correct me if I am wrong. The cdi they list is from 80 - 83 with a square connector for honda. 84 is round. So if I buy that connector they sell I could use a cdi from any other model atc with a cdi from 80 - 83 on the 84? Does this mean those years CDI are all the same except for the connector? If that's the case does it matter about engine size or is the voltage not a factor between bikes?
    thanks.
    Sep 2007
    976
    No one knows?
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    i asked the same question to a friend that raced an older 250r (84) and he told me that you can swap some cdi's as long as you have the same type of wiring? what that means i do not know. i will try and ask him again to clerify this for me.
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
    Sep 2007
    976
    Well I think he is refering to the cdi connector. On the 85 110 I have the wiring harness looks the same except for the connector. As long as you line pins up correctly then why would it not work?
    sbjones73's Avatar
    wisconsin
    414
    i talked to my friend again. he said he had a list of cdi's that will fit others. but need to make your own connector. he uses just the weather pack connectors. i looked at his and he has almost all of his 3wheelers and 4 wheelers wired with weather pack connectors. i guess if it works for him.
    84 250r gone,
    Sep 2007
    976
    Quote Originally Posted by sbjones73 View Post
    weather pack connectors??
    Edit these: http://www.weatherpack.com/ ?????
