Thread: How can I get a key for an older Honda?
    Nov 2004
    Waterloo IL
    2,701
    I've got a 1972 SL70 and the ignition key is missing. It's just unplugged which eliminates the need for it and I just use the kill switch but I can't use the head light like that. There is a number on the ignition switch but my Honda dealer said they can't get that key anymore. I would think they should just be able to cut one off the number but they say no. Does anyone have any idea?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Pa.'s Highest City
    8,058
    I lost my only key once.. I took the ignition to a local locksmith and they fixed me right up. Cost me about $25 tho.
    Dec 2002
    deer park, texas
    2,336
    Locksmith is the only way. They might not have that key blank anymore so he will need to retrofit it to another. You could always do it the old school way. Drop the tumblers and use whatever key you like or a screwdriver.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by barry_mann View Post
    How do I do that with the tumblers? The dealer gave me like 5 old keys that were close on numbers that he thought might work so I could just use one of those and no one would know.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Dec 2002
    deer park, texas
    2,336
    If you can get the cylinder out you just remove the protective metal covering and dump them out. Every ignition switch is built diffrent as how it comes apart. So you will need to look at it. If it want come apart without the key ( which is how most of them are ) then get you a skinny nail and a . You can look in the key hole and see the pins at the top. There should be about 4. Using the nail, knock out the first one, then on and on. It takes some time. After you have them all broke loose blow it out with air and kinda force the new key into it. It might take some slight ing. Hammer it a little bit and pull it out. Keep doing this until it goes all the way in. The main reason for this is there will be partial pieces of the pins in there. Your basically moving them out of the way. Now with the key in turn it over. It might take some pressure because of partial pins. This will make everything look normal. Now if you dont care, find a screwdriver approximatley the same width of your key. Hammer it in there. Use channel locks to turn it over. then you can use they key or whatever else you want for now on.
    Minnesota
    784
    http://www.hondakeys.com/ I ordered a key for a '76 trail 70 from this site. You have to know the 5 or so digit number off of the ignition to get the correct key. Good luck, I was very happy to find that site.
