how can i get the break the bead on my tires.
84 kxt250 tecate3
87 kxf250 tecate4
88 yfm100 yamaha champ
85 200x high compression screamer
Dam'n your bike must be fast! You were haulin ass when i passed you on my KAWASAKI
Run it over with a car tire, use a backhoe, use hydraulics from any type of out rigging or go to MR TIRE SHOP.
MR TIRE SHOP always costs money but aggravation costs allot of stress!!
Get another person to run it over with a car or truck. Just work it back and forth add some soap and water to the bead. Just keep working your way around the tire, it will come loose. Put down a rubber mat so you don't mar your rims up.
YTM-200, Wheeling machine!!!
1985 Honda 200x...
...Just a simple mild 200x
Have some one else do it![]()
Curse alot!
DONT use a sharp object to try to break the bead...
I used a crow bar thinking it wouldnt hurt it... it worked for 1 tire and I slipped with the other tire and ruined it... it was almost junk anyways tho...
after that I got out mr.sawzall and cut the b!tch off the rim! lol![]()
if you dont care about the old tires you are good for almost anything.... but dont ruin the rim doing it... lol
Taking it somewhere is always easiest... and even they dont have the best luck.... even with the machines... atv tires suck to mount/dismount.
Roger
1984 Honda ATC 250r
Bored .020 over Wiseco, Answer silencer, fresh motor, New connecting rod and balanced crank, Boyesen 2 stage power reeds
what i did was find an old truck/car tire rimm, place it on top of the tire, then jacked up a f-150 4x4 truck, slid the tire and the old truck rim under the rear chassy, lowered the truck on the rim. then got into the back of the pan of the truck, and started jumpping like hell. after a few jumps, POP!! the bead was broken, then i fliped the tire around and did it to the other side.
I have made really good friends with the fat service writer at walmart. She always gets it done for free but usaully takes all day. It is amazing what a few winks to a fat lady will do.
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
1981 Wife ( Project)
I just go to the local atv shop. Five bucks on, five bucks off. Worth every penny in saved aggrivation.
$80 !!!!!!!!!!!!!!!!!! Oh My God. So if i wanted to replace my front tire it would be $160 just for the mounting???? I think i would be finding a Discount Tire or something.
Couldnt you buy a new rim and tire already mounted for what they want just in labor?
the old bumper jack method works for me. if you have a truck that still uses the old style jacks.
If you go to a NAPA store ask them for their tire hardware book. In it you will find a bead breaking tool that they use on car tires. It is about 5 feet tall. it is a big piece of pipe with another pipe in it that slides up and down with a special tip on the end. You basically put it on the bead and slam down the plunger. It sounds kind of lame but i have one and it works. i have also seen it used on 18 wheeler tires. It is the same principle as the crow bar andbut safer for your havds and the tire/rim. i think it was like $60.
Buy one of these...... its $40, and I can get any atv/atc tire off in a couple minutess.
http://hyperracing.com/product.asp?prodid=80-003
It is for 10" rims, but you can make any size you want just by making a new arm, which just consists of drilling a hole in one end and a notch in the other... if any one wants pics let me know..... I was always changin tires for flat track racing and it works great for the harder knobbies too.
84' Yamaha Tri-zinger 60
85' Honda ATC 70
84' Honda ATC 70
83' Honda ATC 70
78' Honda ATC 70 (140cc lifan)
79' Honda ATC 70
73' Honda ATC 70
85' Honda 200s
83' Honda 200e
85' Honda 250sx
Jlatv sells a bead breaker, that is adjustable from 8" to 11 or 12" wheels. It something like $80, well worth it. I have 3- 17" tire iron @ ~$15/each. I got them 2 years ago and lost count of how many tires of mine and friends I took off. I don't have to pay anybody to change tires. If you get the techniche right, atv tires are easy to change. I also do my dirtbike tires myself too, 2 dirtbikes ridden partially on the street, go through tires quick.
