Results 1 to 11 of 11
Thread: ATC 70 BIG MOTOR SWAP?? Lifan or Honda???
    OHIO
    2,857
    Can anyone tell me what Lifan engines will bolt and go on the 78-85 atc 70? What about the honda 90 or 110? Looking for some suggestions to get a mad 70 finished up!! on3eatin4........... any help appreciated, gotta go ride some 70 wheelies across the yard to keep the neighbors guessing??? Lovin it !!! madtriken to you all....
    Baltimore, MD
    6,088
    90/110 engines have to be modified or at least the frame has to be modified for the 90/110 engines to fit. All the lifans from 50-150 bolt in. But most of the time you have to have a different intake and then do some wiring. Then you have to figure if you want electric start or want to turn a kick start engine into a pull start engine. If you go electric, you need to mount a battery and such. It takes a little work and a little planning, but worth it in the end.
    Bartlett TN
    3,083
    I have a 110 lifan bolted on mine right now, just to ensure the fitament. As stated above those are pretty much the main thing you have to realize when putting a lifan. You cannot use the kick starter without adding some wheel spacers and trimming the fenders.....as they get in the way. But most that have the kick starter, also have E-start. For the battery and electrics, you have to use your imagination and do whatever works for you. It is endless what you can do to the buggers, its all up to you on what you like. As far as the motors are concerned, I think they are all fine. I have never heard of anyone having issues with the chinese motors.
    86-87 Tecate ROCK!
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    You could try a GPX motor?
    Apr 2008
    NW, IND.
    842
    The electric system might be different 6v to a 12v too. Doesn't take much to change. Good engine to mod. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Dec 2002
    salem, nh
    1,339
    lifan all day.
    <---138 lifan w/ kickstart
    electric start was too much hassle. no you dont need to extend the wheels to use the kicker. i just cut like 1 inch off of the kicker and it's fine. it's easier to stand in the front of the trike and kick it forward with your foot than to kick it backwards like your supposed to because the wheel is in the way.
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    topless is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    Kansas
    160
    We modified a TRX 90 pull start to use on the Lifan. The motor is one of the hot rodded 138cc Lifans and to start it, we put a bigger pull handle on the rope and wear a glove. If it kicks back, it will jerk that "T" handle right through your fingers, bare handed. It only took a couple of times before changes were made. It takes a little machining, which we can do, to use the pull start, but it kept the fenders intact.
    Dec 2002
    salem, nh
    1,339
    Quote Originally Posted by topless View Post
    oh yeah, i dont have fenders
    i'd post pics but i'm at work. if you search the atc 70 forum on the glamis dunes site you'll find everything you need to know, including pics of mine
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Terryville,CT
    1,616
    POST UP SOME
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Nov 2014
    motor is shot on 84 ATC 70. Would like a pull start 90-110cc automatic transmission, not sure they make them or pull start adapters.
    It is for grandkids.
    Jul 2012
    Seattle, Washington
    1,543
    Quote Originally Posted by doug357 View Post
    https://hondaatc70.com/products/bill...market-engines
