Changing crankshaft pin... motor rebuild! 84 250r
Hey,
I seperated the cases of my 1984 250r and got the crank out easily....to find the main bearings shot.... got those coming now too...
What oil goes in the bottom end?? I know its gotta be either regular oil or some heavy gear oil....what is suppoed to be run??
I got a new connecting rod and bearings/pins kit and need to install it now...
The crank is out completely...
How do I get the pin out of the crankshaft to change the conencting rod?
What direction does it come out? Go in? (stator side to gear side or the other way around??
ALSO, what do I need to check while Ive got the cases seperated? All the bearings seem fine except the main ones....they are coming...
Thanks,
Roger
1984 Honda ATC 250r
Bored .020 over Wiseco, Answer silencer, fresh motor, New connecting rod and balanced crank, Boyesen 2 stage power reeds
