Well I got the bike up and running great now.. Bored it .50 over and New wiring did the trick.
I bought the clutch parts including the cable plunger and spring but doesn't run right with it installed.. The bike will only run wil the choke open but it runs at wide open throttle and stays that way no matter what you adjust. When its closed the bike stalls even when warm.. I Remove all the choke items including the plunger and it runs with no issues at all.. I have the mixture screw set at 2 turns out.
And info to get this worked out would be great.. After spending $60 on the choke parts its a little waste if I cant use them.
Thanks
Chris
