Thread: tri-z exhaust seals need help
    Jul 2008
    hickman, ky
    44
    ok does anyone know where i can find exhaust seals for my 85 tri z
    Pa.'s Highest City
    8,058
    You can buy all the gaskets new from your local dealer. (that one cup shaped gasket is about $20 tho!) or get them from bikebandit.com.
    Alot of guys just load up the end of the chamber with hi temp RVT.
    Jun 2006
    Ohio
    2,294
    I moved this post to Trikesylvania forum for you bzerk.
    When you have a tech question,you will get more reponse in this forum than where you have been posting,
    I agree with Chris200x.
    The best way to seal them,is load up the pipe with, The Copper type, HI- temp Gasket maker.Even with the factory seals,the pipes will leak,unless you use that stuff.And let it set up for 24 hours before you run the bike.
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
    Columbia
    5,131
    Its good to get the factory cup style gasket, AND use the hi-temp sealeant. That will give you a perfect seal!
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    ive never had luck with the stock exhaust flange gaskets (speakin for z's only). as mrs. mosh said the copper stuff works best as it is high temp and fuel resistant also. i always thought about using o rings on the flange that metal stocker gasket just never worked for me.
    Current Rides-Soon to be 85 350X, 84 200X
    PastRides
    86 250SX 85 Tri-Z (yellow) 85 Tri-Z (silver) 86 200x 01 Blaster 99 Blaster 85 ATC250R 86 ATC250ES 84 Tri-Zinger 60 ATC500R Project
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
