Results 1 to 15 of 15
Thread: In need of your opinion on a TECATE
    Atc GuY's Avatar
    Atc GuY is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    Michigan
    238
    I know a guy that has a 1984 Tecate that is in "parts bike shape" as I would call it. I really want to get it, but some searching of the boards has shown me that parts are REALLY HARD TO FIND! So what I need you to tell me is this going to be an expensive restoration $100's? I'm not worried about the length of time to get it running but how much it will cost. He wants 200$ for the trike, which I know is a good deal. (sold my go kart and ATC 110 and have 427$ in funds) I dont care if the parts are new or used but it has to look nice. I'll list what I know it needs:
    -New levers (hand clutch and front brake)
    -Front brake cable
    -Rear brake hose and parts that attach to brake lever
    -intake boot
    -kx CDI (it has kx flywheel and stator but do I need a kx CDI?)
    -exhaust silencer
    -grips
    -seat cover
    -new brake pads
    -front tire
    -front fender
    -grab bar
    I can sand the rear plastics that are on it because they have no cracks in them. Radaitor is in great shape, not shure about clutch/ bearings. Rear tires/rims look usable. Don't have pics now but may have them tomorrow. So what do you think?
    Jun 2006
    Willow, Alaska
    1,337
    Sounds like most of that is just 'universal' parts or stuff thats easy to come by or can be bought new, with the exception of the intake boot. For 200$ id go for it.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    sounds like a good deal pics unseen. but if your worried about spending hundreds on a resto, id forget it. its more like thousands, it gets addicting ordering up parts all the time
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Ok I'll still look into getting it. If the flywheel and stator were on and it was getting spark I'd bet it would run as-is. I'm dabating because I can get a 200x for 400$, havent seen it though... I'll keep you updated...
    Sep 2005
    MICHIGAN
    2,027
    I have a whole 84 Tecate project like that for sale here in Michigan. It runs but 3rd gear of the 84 KX250 trans is bad, but I have a whole other motor/trans to fix it. So parts are available and probably not as far from you as you think.
    http://www.3wheelerworldforums.com/s...ad.php?t=85637
    86 T3
    84 T3
    86 KX250
    Oct 2005
    saratoga, ny
    2,819
    levers are easily obtained.
    motion pro still has the front brake cable.
    rear brake hose can be found from another brake setup, the parts for the rear brake can be found, probably place an ad in the classifeieds, sure they are around.
    intake boot...well condition depending, you can fix a cracked one with some plyer grip, or try and find one for a kx or any year t3 for that matter.
    grips, ha, anywheres you find other grips.
    brake pads, dealer or bike bandit.
    kx cdi will be needed, not interchangeable with a kxt, ebay or classified ad.
    seat cover, can find them on ebay stores, verde, etc...
    front tire, kenda max or something around the same, geeez i have even seen trail pros used for the front, lol.
    front fender is still availible thru maier.
    grab bar thru prm.
    for 200 i would grab it, but thats just me and my opinion. i am a t3 nut, so!!!
    NE Indiana
    1,067
    It's worth $200 IMO
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Thanks for the fast replies, I think I'll go for it... I'm in need of a good project.
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Also, do I need the whole wiring harness and CDI? Or just the CDI inniter?
    2quicktecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    wa
    398
    get it you'll love it. i bought my 84 kxt for 350 looking like this
    and a million bucks later
    not quite a million bucks, but i actually did alot to it, new motor, brakes, exhaust, tires, bearing and seals
    84 kxt250 tecate3
    87 kxf250 tecate4
    88 yfm100 yamaha champ
    85 200x high compression screamer
    Dam'n your bike must be fast! You were haulin ass when i passed you on my KAWASAKI
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Ok I searched for some kx swaps and saw a post saying that a kx125 ignition system will work. Here's my new question: With the kx250 flywheel/stator that is on the Tecate will a full kx125 ignition system plug into the 250 and work? I'm asking because the seller has kx125 part bikes...
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    2quicktecate, nice bike, and great find!
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Bump........
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by Atc GuY View Post
    The 125 parts may bolt on and function, but the timing advance will be wrong for a 250... its asking for disaster iMO.. the ignition system from just about any year Kx250 should work.. what year is your kx flywheel and stator?
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Not sure. The guy isn't calling me back either!
