Results 1 to 12 of 12
Thread: oil questions
    Apr 2008
    Brandford florida
    20
    oil questions
    I'am get ready to do a oil change on my little 185s,and I would like to know what kind of oil you guys run in your triks.
    Also how often do you change you oil?
    thanks
    Lukester
    Dec 2005
    Wisconsin
    1,141
    Golden spectro 10-40 in all weather from -20 to 90 above. I run it in my ytm-200. Works real good. I like it a lot.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    I'd run a full synthetic. I run that in all my bikes/trikes. I'm not sure people understand the torturous conditions these small engines are put through and the more protection you have, the better.
    Maine
    18
    Castrol GTX 10w-40
    Pa
    15
    I use Bell Ray 10-40. I change it every 3 months.
    Feb 2008
    NW Indiana
    411
    http://www.royalpurple.com/
    In my 350x I run Royal Purple and only Royal Purple. In the battle trike I run whatever's handy.
    I run Walmart 10W40 Valvoline oil (10$ for 5 quarts) and if you guys have ridden with me, you see that I have plenty of power, no smoke and no reliability problems whatsoever.....
    I beat the absolute SNOT out of my 350X and I do it often!!
    TO EACH THERE OWN!!!!!!!!!!!!!!!
    swanzey,nh
    67
    cheap oil changed often.good as new
    I'm tellin ya, synthetic all the way...
    Sep 2005
    central Illinois
    651
    isn't regular motor oil not as good for the clutches? Thought you should run an oil that is compatible with the clutches like Yamalube?
    Texas 200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Corpus Christi, Tx
    296
    Mobile1 10w-30 I run it in everything I own. Synthetic all the way!
    Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
    Feb 2008
    NW Indiana
    411
    Quote Originally Posted by pickleweasel_00 View Post
    Historically, it's the synthetics that are rumored to be bad for the wet clutches and dino is supposed to be the only way to go. Modern synthetics are perfectly fine (typically). Myself, I can only speak for the brand that I personally run and I can tell you with no uncertainty that it works fine. (read the FAQ on the website)
    Think about when synthetic oils really hit the market and how long wet clutches have been made.(hint: synthetic motor oil was first invented in 1966)
    Also remember back in the day that Chrysler had warning stickers on vehicles stating that the only radiator coolant compatible with the vehicle was MOPAR brand coolant. In other words, since the beginning of time manufacturers have been claiming that any oils other than their name brand would destroy wet clutches. Maybe for a couple years this was even some truth to the idea that the new fangled synthetics were bad, but I think there's plenty of evidence now to the contrary.
