Thread: is it worth it? engine related.
    DarkestGKnight's Avatar
    DarkestGKnight is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Babylon
    448
    ive been slowly restoring my 1978 kawasaki kl250 and is it worth cracking the cases and replacing the bearings? casue they have never been opened up. thanks tim.
    1982 yamaha rx50.
    2001 murray minibike with 5hp.
    fully modded goped.
    250cc 4 stroke shifter kart in the process.
    Sep 2005
    Lipetsk, Russia
    2,824
    Is it a four-stroke? If it is, and the engine always had a good amount of oil in it, wasn't left out in the rain, etc, I would just leave it. Unless you're planning on making the engine some sick race engine, which I doubt, it'll be fine.
    On a two-stroke, it's always advisable to replace the bearings, especially one from 1978.
    Nov 2006
    Babylon
    448
    its a 4 stroke and the engine is in decent shape, and no i plan to leave it stock. i dont think ill crack the cases then, thanks tim.
    1982 yamaha rx50.
    fully modded goped.
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by DarkestGKnight View Post
    The only question I have is... who is Tim? That sure as hell ain't my name.
    Also, you might want to set valve clearances on it, though. Buy a gasket set if you can, just in case.
    Nov 2006
    Babylon
    448
    haha i ment thanks and then put my name im tim lol, and i have a gasket set, rings, valves and valve seals on the way already.
    1982 yamaha rx50.
    fully modded goped.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    checlk them. if they feel tight (NO PLAY) then let em be. if there even a little loose, replace them since its half apart already.
