Results 1 to 15 of 17
Thread: ack! Oil check screw stripped?!
    Internet
    1,251
    So I let the screw go today just to check the oil and now the damn thing won't go back in tight!!
    Suggestions? Teflon tape maybe?
    Aug 2004
    Nampa, Idaho
    1,245
    Is it the case or the screw that stripped?
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    2000 Ford Explorer Sport
    Dec 2002
    deer park, texas
    2,336
    Can you tell if it is the screw or the threads in the case? If it is the screw i would just replace it. If it is in the case then you can tap it out to the next size. Of course if you do this then you will get metal shaving inside the motor. Flushing it repeadly will probly get them out but that is a decision you will need to make. You can always remove the side cover and tap it but that is alot of work.
    Teflon tape should work. It doesnt have any pressure on it, but i will still call it a temp fix.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Internet
    1,251
    Looks like it's the case that is stripped. *groan*
    I'll probably try some teflon tape for a temp fix. Have it tapped out later. LOL, I think my luck is quickly slipping here. What looked like an 80 dollar 'go fast fun trike' is starting to look likie a 'high dollar restore and replace everything trike'
    ROFL!
    Dec 2002
    deer park, texas
    2,336
    hahaha, that must be contagious. That is exactly what happens with every trike i get.......... Damn, got a flat. Might as well tear her completly down and fix everything.
    Andrew_250R's Avatar
    Andrew_250R is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2008
    New Salem, ND
    157
    The poor thing is 26 years old, give her a break LOL. I would teflon tape it also until you can find a permanent fix. If teflon won't work you could use RTV.
    81' Honda 250R ( FOR SALE )
    85' Honda 250R ( FOR SALE )
    Internet
    1,251
    Quote Originally Posted by Andrew_250R View Post
    Yeah, I was half thinking of putting some kinda adhesive on there anyways because really, I won't really be checking the oil down there too often right?
    Jul 2008
    New Salem, ND
    157
    Quote Originally Posted by Saul View Post
    That is up to you I guess. It doesn't hurt to keep and eye on it though. If your crank seals go out I believe the piston will suck oil out of the trans and you might not know unless you check the oil, someone correct me if I am wrong.
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    yea if the crank seals go the motor will eat the oil, it usually smokes pretty bad when that happens though.
    let me correct that. if the crank seal goes on the waterpump side you will suck in oil, if it goes on the stator side you will suck in air.
    correction correction, lol. being that you have an air cooled the crank oil seal should be on the foot brake side, don take this completely to heart though i am basing this off of liquid 250s, but is more than likely the same, my head hurts, someone get me a beer,lol
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Jul 2008
    New Salem, ND
    157
    Quote Originally Posted by Tri-Z Pilot View Post
    I agree cheers
    Internet
    1,251
    I think I'm gunna JBWeld the thing. I've got a feeling teflon tape won't hold it very well? And to try and tap a bigger hole is gunna be a huge pain in the butt.
    Groan. Not a fun day.
    Central PA
    1,952
    shouldnt be that hard to tap, just take off the side case and do it. the side case does come off doesnt it? i know next to jack about the air foolers. maybe theres a tap that allows you to chase the threads without getting shavings on the inside, i think they make something like that for spark plug holes, dont know about something that small though.
    PastRides
    SOON MY PRECIOUS!
    Internet
    1,251
    I dunno - I gotta size it up better tomorrow. Maybe I will be better off having a bigger hole tapped.
    Dec 2005
    Wisconsin
    1,141
    Just pack the tap with grease that will hold the shavings as you tap the hole bigger. Your making things harder than they should be, thus bringing problems to yourself. Tap that baby out and get the proper bolt and it will be fixed. You spent all this time and energy trying to half ass the problem when it could be fixed, and done right.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    central mo
    107
    If you tap it bigger, pack your tap with grease. The grease will help collect any shavings and keep them out of the case. Another option is Permatex Thread Repair. Should be able to get at any auto parts store. Works pretty good if you follow instructions.
    Either way good luck with your repair,
    Cars
    My Trail Pros will out last your Quad
    84 125m tore down
    87 125m
    85 200m redoing top end
