Page 3 of 3 FirstFirst 1 2 3
Results 31 to 43 of 43
Thread: Pics of my atc 500r project
  1. #31
    Nov 2006
    Ga
    103
    We made two lower frame rails that located the engine where we wanted and we were able to modify a CR 500 pipe to fit rather well. I will try and get some pics of the lower frame posted tomorrow. Thanks to everyone for the comments.
    84 Tri Zinger 60
    84 ALT 125
    84 ATC 110 (blue)
    85 YZ 490
    85 ATC 125M
    85 CR 500
    85 Tri Z 250
    85 Quadracer 250
    86 Tri Z 250
    86 ATC 350X
    (2) 86 ATC 250R
    86 Tecate 250
    87 ATC 200X
    87 ATC 250SX
    (2) 87 Big Reds
    88 Quadracer 500
    01 CR 500 (new)
    04 KX 500 (new)
    06 Banshee SE (new)
    07 CR 125 (new)
    07 CR 250 (new)
  2. #32
    illinois
    743
    so how is it to start it ? stock is a pain in the @##, i cant imagine that little kicker,and kicking it backwards
  3. #33
    250rs-neva-die is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2008
    Massachusettes
    191
    looks nice dude, how many mods did you have to do to the motor mounts? i have wanted to do build one of those for a few years now? havent been able to find much info or trike fanatics until now to ask ?'s and what not. get back to me if you could thanks
  4. #34
    Nov 2006
    Ga
    103
    To get the motor to sit like we wanted we used portions of a CR 500 cradle and set the engine a little higher than some others I've seen, and while everyone has a personal opinion on how things should be, our main goals were to have perfect sprocket ailgnment, not have too much forward angle of the cylinder, and not to have the motor sit too low in the frame rails. I also wanted to be able to work around the top-end of the engine if need be. I am going to start a new thread with some updated pics and a nice little trick part that aids in starting
    84 Tri Zinger 60
    84 ALT 125
    84 ATC 110 (blue)
    85 YZ 490
    85 ATC 125M
    85 CR 500
    85 Tri Z 250
    85 Quadracer 250
    86 Tri Z 250
    86 ATC 350X
    (2) 86 ATC 250R
    86 Tecate 250
    87 ATC 200X
    87 ATC 250SX
    (2) 87 Big Reds
    88 Quadracer 500
    01 CR 500 (new)
    04 KX 500 (new)
    06 Banshee SE (new)
    07 CR 125 (new)
    07 CR 250 (new)
  5. #35
    Oct 2008
    Nazareth, PA
    Hey Prohemi500,
    The trike looks awsome!!! Thanks for all the info. I've been thinking about building something like this for a long, long time now. I've seen alot of builds like this and this is by far the best ever..!!!! You should go into business with the guy that help you out with the frame and start modifying/building them for other people! I know I would be one of your customers! I'll be looking forward to more pics! Thanks!
  6. #36
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    That looks slick, loving the foward kick! Do you have any mods in the motor?
    TF 07,08,09,10,11,12,13,14!
  7. #37
    Feb 2008
    Orange County California
    726
    Cool
    Agreed, That is way f#$kn' cool
    Mucho props Bro!
    1986 ATC250r
    1984 ATC70
  8. #38
    Nov 2006
    Ga
    103
    I've been lazy the last couple of weeks and have not posted any more pics, but it wont be long now because I have some more info for you. The ATC kicked fine, and yes, it was slightly harder to kick than the bike version, but not much worse! Just to aid in starting, I have installed a compression release. Dont laugh yet, it is a very trick little piece that you can hardly see, and it works great!! The bike now kicks with a little less pressure than a standard 250R and greatly reduced stress on the kicking mechanism (and my leg)!! The kicker has been modified as well to fit the plastic and to answer the question on engine mods, it is a stock 85 motor, but I would like to put some V-force reeds, a 41.5mm taper bore keihin carb, and do some port work on the cylinder. i am trying to get everything ironed out before I take the motor back out for mods as well as powdercoating the frame, etc. I will get some more pics soon!
    84 Tri Zinger 60
    84 ALT 125
    84 ATC 110 (blue)
    85 YZ 490
    85 ATC 125M
    85 CR 500
    85 Tri Z 250
    85 Quadracer 250
    86 Tri Z 250
    86 ATC 350X
    (2) 86 ATC 250R
    86 Tecate 250
    87 ATC 200X
    87 ATC 250SX
    (2) 87 Big Reds
    88 Quadracer 500
    01 CR 500 (new)
    04 KX 500 (new)
    06 Banshee SE (new)
    07 CR 125 (new)
    07 CR 250 (new)
  9. #39
    Mar 2005
    overton, PA
    5,257
    lokin sweet dude
  10. #40
    Masshole
    2,191
    Any new progress or pics??
  11. #41
    Escondido,CA.
    111
    Nice 500!! I have been looking to buy a 500 trike. The sound and performance of a 500 is amazing!! That must have been a tight fit!!
  12. #42
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Is there a step by step thread to build one? I have a 1985 frame and 2 500 motors comming soon.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
  13. #43
    volfan537240 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Eufaula, AL
    292
    Quote Originally Posted by Tecate250 View Post
    That would be nice
    85 tri-z (in pieces)
    421 cub banshee
