Results 1 to 15 of 19
Thread: anyone recommend a good tap and die set?
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    seen some 80 piece sets on the bay with bin's of around $20-50, and the name brand stuff well into the hundreds. is the cheaper stuff ok for occasional use, or just plain junk. i figure you get what you paid for, you bring a cheap set like that home next thing you know theres change missin off the dresser and your daughters knocked up. ive seen it a hundred times,lol
    anyhoo, let me know what you guys use and how you like it.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    central mo
    107
    When it comes to taps you get what you pay for. Ever try to drill out a broken tap? A cheap one is easy, a good one is a pita.
    A decent set is A Jet brand 110 piece set. It's an import and will run around
    $300. Some of the best taps are made by R&N(Reiff & Nestor). American made, privately owned, and expensive.
    I have a Jet set and it works great for me.
    My Trail Pros will out last your Quad
    84 125m tore down
    87 125m
    85 200m redoing top end
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Well in the garage at the farm we have a mastercraft tap and die set. Cost +/- 50$ and we never broke any piece. And I think they have a lifetime warranty
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Aug 2004
    Nampa, Idaho
    1,245
    I have a set from Harbor Freight but I don't know about the quality. I have not broke any of it yet. Its probably like most of Harbor Freight's other tools. Lifetime warrenty but best only for light duty.
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    2000 Ford Explorer Sport
    na
    5,702
    When it comes to tap and die sets,do not buy cheap crap.
    They are brittle,and will break very easy,then you are in for a world of hurt.
    Best brands out there,are Snap-On or Matco....
    You can just get a metric kit too and save money,since standards are just about extinct,unless your working on Harley's or tractors,or old cars.
    Proudly NOT a member of
    "Team on the Teat"
    Frewsburg NY
    1,169
    If you cant afford the snap on or s k you can always go to sears and get a craftsman set. they are around 100 if I remember correctly.
    Las Vegas, NV.
    2,490
    I would suggest a quality HSS (High Speed Steel) set as opposed to a carbon steel set. HSS can withstand more heat & will therefore stay sharper longer. But, I guess it all depends on what you want to use it for. If you just need to re-tap the occassional boogered up threads, then a carbon set will probably be just fine, but if you're cutting a lot of completely new threads, I would opt for the HSS set.
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Quote Originally Posted by moshman355 View Post
    Agreed, those are probably the best two for the money, but you pay a good amount for them, but they will last forever.
    TF 07,08,09,10,11,12,13,14!
    Mar 2007
    Howard Beach, New York, United States
    687
    Quote Originally Posted by Tri-Z Pilot View Post
    woohoo Tommy boy, darn those guarantee fairies
    Current Project:1978 Pontiac Phoenix 355 v8
    Past Bikes: 1999 Yamaha Big bear 350, 1981 Yamaha XS 400, 1996 Yamaha yz250 1984 Honda big red, 2004 Xtreme cr107, 1999 Yamaha bear tracker, 1999 Suzuki ds80 STOLEN, 2005 Kawasaki klx110, 1986 Honda trx200sx
    Daily Driver: 1990 Buick Electra Park Avenue 3.8 v6
    Jan 2005
    Jones, Michigan
    1,821
    well today at work i was installing a compressor mount on an 08 gmc 5500 and got to put strap-on to the test. The idiots at carrier who built the mount didnt tap the holes for the compressor. It was only 1/4 inch steel but we managed to break off two 8X1.25 snap-on taps trying to thread the holes. we barely put any pressure on them either. the second one broke when we were backing it out. We used plenty of oil and had the hole drilled out the right size. my buddy has the big snap-on set (I think over 100 pieces) and it seems to serve us very well. We have used it several times and havent had any troubles until last week one of the "v-block" shaped pieces in the tap handle broke and then today the 8X1.25 tap snapped off. I have a set of the harbor freight taps and they are complete junk. I wouldnt piddle around with a $20 set but i also dont know if i'd spend the $300+ on a snap-on set.
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Aug 2005
    Lockport, NY
    2,395
    Well when it comes to taps. I'd never buy just a set. Sets most of the time have way more than what you need. I also dont like sets because most sets are designed around a four flute tap. These are basically good for chasing holes. They are prone to failing. They break very easily. I definetly would suggest some good three flute spiral taps. These clear a hole easily and are nice strong rigid taps. I would also not suggest HSS. I would get a decent coated tap. Get your self a nice quality tap handle as well. I would suggest the Starrett 91-A and 91-B models. Best tap handle money can buy. They hold a tap tight! I would recommend a 4mm x .7, 5mm x .8, 6mm x 1.00, 7mm x 1.00, 8mm x 1.25, 10mm x 1.25. This is what you need to get the job done most days. Hope that helps IMO.
    Aug 2005
    Lockport, NY
    2,395
    I would suggest buying from McMaster-Carr or MSC.
    Nov 2004
    OH.
    2,487
    Sorry buddy but Irwin makes all the tap and die sets for crap-on, Matco and Mac so they're all the same. Sorry to rain on your parade. The difference is you don't always get a lifetime warranty through most. But guess what. Mac is lifetime warrantied. And we sell them individually. Most common ones run a few $$ to around $15.00.
    P.m. me for quotes.
    na
    5,702
    Quote Originally Posted by seadoo650 View Post
    P.m. me for quotes.
    I knew you would kick my in the jimmy for that .........
    I have a MAC standard set,and it has broken more than my Crap -Ons
    But I bought that MAC set back in 93.I doubt they were made by Irwin back then.But who knows.
    The only problem is, we have no MAC tool dealers up here.Been that way for about 10 years now. .So I quit buying their tools.I dont have time to mail crap in a wait for 4 weeks for the new tool to get warrantied..So I just started replacing them with the other guys stuff,that could be serviced quickly,when they broke.
    Maybe you could put in a good word for a MAC Tool guy up here!
    My Strap Ons have broken a few times,But they have always been warrantied.
    I would have gladly suggested Mac tools,but they are hit in miss as in availiability of dealers.I hope that changes.You guys have better prices,and great products..
    On a side note,I bought the Walton Tap extractors for removing broken taps.Those things rock out.
    "Team on the Teat"
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    I'd concur with the reccomendation to purchase a set or even individually from McMaster Carr or MSC Direct. Select one of the name brand USA made ones (Very spendy, compared to imports, but worth every penny)
