Results 1 to 7 of 7
Thread: Is there a way to fix a sloppy 350x kick starter?
    Nov 2002
    Kirkville, NY
    3,831
    The kicker on my 350x has a lot of play in the joint is there a way to fix this? I thought I remember other members using the part that clamps on to the kick start shaft from another ATV which fixed the problem because it was that part of the joint that wears and the other ATV has electric start so the kicker isn’t used as much. I think it was a 250es, 250sx, trx250 or something similar. If I am on the right track which model was it? If I am dreaming something up do I have another option?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Apr 2006
    Crestview, Florida
    2,429
    im pretty sure its from the SX
    Rides
    85 ATC350X
    85 ATC200X
    PA
    3,515
    i just drill the pivot hole out and make an oversized pin....works great
    WWW.HREATV.COM
    Nov 2002
    Kirkville, NY
    3,831
    John, I remember Bruce using a different kicker part but when I found one post about it he wasn't sure what the other kicker was from. I though someone identified it later but now I can't find that thread, maybe I should just give Bruce a call.
    Swigin, have you had any problem with breaking kickers? My motor is stock so drilling it out a little shouldn't weaken it too much.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    CENTRAL NY
    1,709
    Ive hd problems with the spring getting sacked out and the kicker not staying in place. so i put some tin foil in the hole as a spacer and then put the spring and ball back in. but like john said lube it good..
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    PA
    3,515
    Quote Originally Posted by freaksfix View Post
    thats one way to fix a kicker that flops out when rideing....but he said his is sloppy not floppy....lol
    WWW.HREATV.COM
    Nov 2002
    Kirkville, NY
    3,831
    I oiled it and now it is both sloppy and floppy lol. I took the pin out and will stop by the hardware store tomorrow to get a bigger one then I will shim out the spring and ball.
    Thanks for the help!
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
