I did a search and didn't get the exact answer I wanted so here is a new thread. What is the stock tire size on the 86' Tecate?
The front tire is 23 x 9.00-11. A quick question for you also if your working up there. Did, or do you have to remove your hub to get your front caliper off?
I have no idea, haven't had the front tire/wheel off yet. The reason I asked is because there is a 22 x 8-11 Dunlop tire and wheel on ebay that the seller claims to be for an 86 Tecate.
Nope- 23x9-11 says the manual.
Guess ill look more into it, maybe my rim is smaller. Thanks anyway
My 86 T3 has 23-9-11 I had to take off the hub to get the caliper off.
Hey, john, how's it going?
You mean the caliper on/off? I think I know now, I had to loosen the hub/rim to slide the caliper off-manual didnt say that. Said to take out the caliper mounting bolts and unscrew the axle/bolt to seperate it from the fork leg.
My caliper hit the outer rim though, and wouldnt come out. I ended up taking the rim and hub off![]()
Yeah, I gotta loosen the hub to rim bolts on the 86, can't remember if I gotta do anything on the 85-
