Results 1 to 9 of 9
Thread: Need help flywheel removal!
    Atc GuY's Avatar
    Atc GuY is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    Michigan
    238
    Hey, I'm tearing my 200x down and need to know which way the flywheel nut comes off R-hand thred or L-hand? Also how to you hold the flywheel? I put it in gear and the sprocket just spins. Any ideas?
    Columbia
    5,131
    You could put it in gear, then have someone stand on the rear brake.
    Dont know which way the nut goes on a 200x, should just be Righty-tighty.
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Ok got the nut off, but not the flywheel. Looks as though I'll need to get the puller. Or I can pick a bolt up at the hardware and turn it with the lathe... Any ideas?
    I dunno about your situation, but I used to use a regular three way puller, similar to a steering wheel puller.
    Yamatrike400's Avatar
    Yamatrike400 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    MINNESOTA
    393
    Yes ive also used that^^ If theres just 2 holes in the flywheel i just stick in 2 arms and it works good.
    Three Air R's
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Ok I'll try that. I didn't know if the holes would stand the pulling stress. I really didn't want to go buy a flywheel.
    PA
    3,515
    just use your front axle
    WWW.HREATV.COM
    rugabugadouglas's Avatar
    rugabugadouglas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    iowa
    269
    a chevy truck stud works just get the thread and pitch and go to the parts store thats what i did
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Got my gaskets!, here's the pic:
    Looks like the seller had bought them before and trimmed the lables offand put his on. Who cares though they look good.
