Thread: Keyed ignition is melted.. can I hotwire it?
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    Small fire, my ignition is too melted to even accept the key, anyone know how to hot wire this:
    Green
    Red
    Black w/ white stripe
    Black
    Nov 2006
    Seattle
    1,552
    Anybody? Someone should know.
    May 2003
    Shediac, New Brunswick
    1,126
    wont it run with them all just cut like that?
    I am pretty sure it will.
    you need to splice two of them together in order to get lights... probably the red one and .. and dunno what other one.
    If you can find a wiring diagram it would be easy.
    '84 Honda 200x
    slow restro
    PA
    3,515
    what bike is it?
    normaly the most you need to do is tie 2 or more together
    WWW.HREATV.COM
    Nov 2006
    Seattle
    1,552
    I got the starter motor to go, blinkers and horn, no headlight.
    Red and black made these happen.
    Its a Honda Gyro
    Apr 2006
    Crestview, Florida
    2,429
    those should do it. Maybe you have a bad bulb or a melted wire. Use a continuity tester and find the ground, then hook the others together.
    Rides
    85 ATC350X
    85 ATC200X
