Results 1 to 14 of 14
Thread: How to ID wiseco piston
    Atc GuY's Avatar
    Atc GuY is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    Michigan
    238
    Hey got the 200x apart and it looks to have been blown up at on time But before the head gasket blew it was getting crazy compression. My question is how to ID if it is a wiseco piston? Right now the piston is a .020 over and looks like the rod is new along with a cam and chain. ( New parts that were on it: flywheel, piston, rod, cam chain guides, cam, cam sprocket ) Could this be a higher compression piston besides the fact that is .020 over? The piston has a "bump" in the middle with slots cut in it for valve clearance. Also the piston has a "C" on it. Valves/seats also look new. Still has hone marks on cylinder. When running it pulled hard and made my foot black and blue to kick over. I ran it on regular gas with no problems. It was harder than a '83 350x to turn over. Any ideas?
    PA
    3,515
    sounds like a 10.25 to 1.....pics?
    WWW.HREATV.COM
    Apr 2006
    Crestview, Florida
    2,429
    Post a pic of it. Might be a 12:1
    Rides
    85 ATC350X
    85 ATC200X
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Apr 2006
    Crestview, Florida
    2,429
    Its not a 12:1, more pics of the sides and under and we'll be able to tell
    Rides
    85 ATC350X
    85 ATC200X
    Mar 2007
    Texas
    5,045
    there's machining marks in the sides so i woudl tend to lean more towards it's a wesico.
    ________________
    https://www.mikesatvfix.com
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Ok, I'll get pics, but it says 4156 on the left had side (from front of engine) and a W on the right
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    Apr 2006
    Crestview, Florida
    2,429
    Answered your own question. 10.25:1
    Rides
    85 ATC350X
    85 ATC200X
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    10.25:1 plus .020 over
    Looks like I did get a good deal
    PA
    3,515
    Quote Originally Posted by Erics350x View Post
    he said it ran fine on pump gas....that was the dead give away
    i never seen a 200x run 12-1 on pump gas and run fine
    WWW.HREATV.COM
    Mar 2007
    Texas
    5,045
    so it just blew a HG?
    if that's the case, i bet he didn't tune it right as it detonated, or the timing was off (not chain but actual inside the cdi area) and it detonated that way. could have ran 87 when he shoulda ran 91+ as well. that running wot could detonate as well.
    ________________
    Atc GuY's Avatar
    Oct 2007
    Michigan
    238
    When I tore it apart everything was torqued wrong. Someone used a cheap gasket maker all over the inside of the head. The head gasket was re-used and was in really bad shape to begin with. Oh well, it will be put together with brand new gaskets so I shouldn't have any problems. It was tuned pretty lean but that was fixed before I rode it. The head gasket was blown on the cam chain side and the kick starter side. But it ran real good before that so it has to run better when I put it back together!
