Results 1 to 11 of 11
Thread: Plastic R tank restoration tips?
    Phoenix, AZ.
    6,719
    I've seen several threads on the subject but can't seem to find them right now.
    I'm in the final stages of restoring a badly faded 85 R tank. Spent a few relaxing hours scraping and wet sanding so far (yeah I said relaxing... I'm weird). I'm up to 1500 grit so I was looking for tips on getting the shine back. Gonna finish up the sanding with 2000 grit today or tomorrow.
    What do you guys use to finish these things up? I've heard of people buffing and using a flame (tried that on a small spot, didn't work out too well for me). What products and techniques are you all using?
    Aug 2002
    New York
    1,098
    I used Mothers Aluminum polish. It came up like new.
    bad350's Avatar
    bad350 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    kentucky
    176
    any type of rubbing compound
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    I used a razor blade standing on edge.It worked the best at getting the faded plastic off with good results.The rest was a bunch of wet sanding with scotch brite pads.
    Phoenix, AZ.
    6,719
    Quote Originally Posted by edog View Post
    I'm way past that point. I used the blade out of a utility knife (thicker than a typical razor blade).
    When you guys buffed it out, did you do it by hand or with an electric buffer?
    bad350's Avatar
    May 2008
    kentucky
    176
    by hand then coat it with tire shine
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    By hand.............
    May 2007
    Coshocton, Ohio
    1,815
    If you use a machine the plastic will tend to smear. I,ve never tried one but an orbital polisher might work because they tend to turn a little slower.
    Appalachian American Racing
    the home of
    Aug 2002
    New York
    1,098
    You will have to do it by hand. I tried a buffer at first and it did smear. Unfortunatley, if your want a great finish, you will have to do it by hand.
    I don't have to use tire shine or armor all on my tank. The polish made it smooth and shine on its own. Good luck and great forearm muscles......
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    +2 for Mothers aluminum polish by hand. Came out awesome on a short track tank I did. http://3wheelerworldforums.com/showthread.php?t=73033
    Jun 2006
    Illinois
    491
    Good to know. I have to do my 250R also. Thanks!
