Results 16 to 30 of 61
Thread: 86 250r Engine noise...what's making it? You tube video to hear!
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,241
    that sounds like a 250r to me,,,,
    May 2008
    Northwestern Ontario, Canada
    552
    Thanks for the input guys...yeah it sounds pretty scarry at first but aside that it runs flawlessly, even idles!!! Again my 2-stroke xp is limited to motorcross and ski-doo's, but none of them made this sound.
    , your engine sounds a lot like mine, especially at idle. I'm trying to make mine 100% stock so I do have the stock pipe but i may update the pipe later on. That would probably drown out the sound because when I hit the gas the sound goes away with the engine rev's so a louder pipe would likely mask it.
    My noise might be sounding a little harder to you guys because I used a pro camera from work to record it...don't know, but again it runs great and I don't really want to tear into a less than 10 hour new engine to find a phantom noise, not when the thing will pop wheelies in 3rd gear without even trying!
    On the upnote, she's almost done! Just ordered new rad fairings (oem), and brakes (yeah I was booting up and down there with zero brakes! Need a new wheelie bar and rear plastic. Then I tear her down again and do the full new paint rebuild. Still not too bad for a bike that every part of it came off of e-bay!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Apr 2006
    Crestview, Florida
    2,429
    No offense, Eric, do you own any 2 strokes? That would be a terrible noise for a four stroke, but mines been making a similar noise for years, and I don't baby her...
    None taken, but for the record
    I've been riding them for 25 years and was raised in a shop. If you listen alittle closer you can hear what he's talking about. It's not a normal noise. It may be just counter balance noise, but it would drive me nut's!
    Rides
    85 ATC350X
    85 ATC200X
    Ontario, CANADA
    4,538
    Your all set, no worries. My duncan PV 265 does that as well!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Jun 2006
    Willow, Alaska
    1,337
    After reading this I feel a lot better, my 250r makes a slight knocking sound from the balancer, and I was about ready to tear down my motor and replace all the bearings!! After revving it up it goes away, but I didnt want to scatter my engine on the trail from bad bearings. Guess I dont have to now!
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Jonpin's Avatar
    Jonpin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Melbourne Florida
    333
    It sounds like when you kick a bike over and have the kicker down still but louder i think and if thats normal for a 2 stroke to sound like more the reason not to get one i would go crazy hearing that all the time ,good luck resolving the problem.
    05 Kingquad 700 85 200x 85 250es 85 350x
    85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
    Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
    It does sound like most R's but something sounds a bit loose to me....
    If you want some piece of mind grab a gasket kit.
    Take off the left cover and see if there is any play in the crank, you can get to the counter balancer on that side too and make sure they're tight and the holder isn't broke. My holder was cracked.....
    Then you can take off the right cover and do the check on that side, it will only cost you 2 gaskets.
    That helps you rule out most of it.
    If it's a "newer" motor, then hopefully whoever did the work checked the lower connecting rod bearing.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    my air R sounds like its coming apart when its running.....and its 100% fresh....i know air and water cooled are night and day difference, BUT.......
    May 2008
    552
    It's literally factory new, never been opened. If you listen at the end of the video after I come back from the quick boot, it seems to be louder! I'll look into the crank, never know what could be up in there but to me it seems like it's coming from near the reeds, someone on youtube said it could be from the starter gear too?
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Starter gear?? It doesn't have a starter gear
    Listen to whoever and whatever gives you piece of mind. If it was a NOS motor, it's very well that the mains or something else could be the problem.
    New doesn't mean much, was it stored in a dry area for 20 years? Did the bearings dry out?
    350X motors cranks that sit for 2 decades lay in oil all that time, 2 strokes rely on the premix oil that lubes them, the more they sit the drier they get including the lower connecting rod bearing.
    No need to get crazy about it, we can all come up with our own ideas and or thoughts, but if you check it out best you can than thats all you can do..........
    Whats the history on this motor??
    cybrman's Avatar
    cybrman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Winter Park, Florida
    254
    It could definitely be something with the kickstart, spring messed up or something. Not sure how the 250r's are put together but I've had that noise on a 250sx with a spring that got wound around 180 degrees. I managed to heat it up and reshape it but I swear to this day I can still hear a small sound roflmao makes me crazy!
    The sound I heard sounds like it could be similar. Only one way to find out. I'm with DC pop the cover off and have look.
    1985 250SX #2 300sx risen from the ashes.
    1985 200X
    1983 200
    1979 ATC70
    1985 ATC70
    1985 ATC110
    1985 Big Red
    Apr 2006
    Crestview, Florida
    2,429
    Quote Originally Posted by Nick_R_23 View Post
    -Nick
    Goes away with rev's? Sounds like you have a bad main bearing.
    Rides
    85 ATC350X
    85 ATC200X
    May 2008
    552
    Well has to have something from the kick starter to some kind of gear...it don't start by osmosis!
    Engine was sitting for the last 20+ years but was properly stored, had been fogged and had proper long term storage oil in the gear case.
    checked the inside when I got it with a borescope, all was well, no rust, still oily from the fog.
    Little bit of surface rust on the crank would not hurt it long term, although I saw no evidence of that.
    Still like to know what exactly makes that noise!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    I say it's normal. Just my .02-
    May 2007
    Coshocton, Ohio
    1,815
    It,s a 250r. They make funny noises. They run like a scalded dog. Ride that sucker for a while and if it gets any worse then worry about it. Chances are you will get used to hearing it first, unless of course you choose to sell it to someone else. If you buy another one, it too will make funny noises.
    I think it,s the nature of the beast.
    Appalachian American Racing
    the home of
