ok before anyone goes further, are we sure the oiling is correct for that motor in the mixture. I've been a crew cheif in karting world for a few years, and that noise sounds like lower bearings going, or even rod end bushing gone. also sounds like piston is scouring the cyclinder walls.
nowgranted the mtoors i tuned were rotax 125s, but wouldn't a 2stroke sound like a 2stroke at idle?
one other thing it could be while thinking of it is reeds are not correctly installed, or worn prematurely.
I do know if I heard that in a motor i was workign on, it's be torn down and sent off to the shop for rebuild (not allowed to rebuild and seal them per racing rules, but i was allowed to dissamble all i wanted for troubleshooting but not assmeble).
I'd look at the oil/gas mixture your running, next check the plug and tuning. tune the carb and get the mixture right. set the plug gap accordingly or even the plug heat range. after that i'd start checking for internal wear.
good luck.
SOON MY PRECIOUS!
