as for the timing, I don't see it jumping unless it stripped a gear; to check your going to have to remove the large round cover on the left side of the head.(its held on by a bolt that goes through the cyl head; the bolt head is on the right side of the cyl. head). then align the cam gear to its mark and the crank to its mark like is shown in your books.
From your initial description, I would have guessed the slide was not in the carb properly and that was causing it to rev up right away. BUT since you have taken it apart and cleaned it and now it will not fire, I'd suggest you take it back apart again and verify everything is clean and the pilot screw is set per the book to start out.
Also you might try holding the throttle open a little--1/4 to 1/2 when starting.
85 200x
84 200x-autox
84 200s--parted out
85 70
85 70
84 70
69 QA50
70 trail70
81 yz250
82 yz80
