Results 1 to 8 of 8
Thread: 350x rear brake caliper question
    Nov 2002
    Kirkville, NY
    3,831
    I am rebuilding my rear caliper but I found a discrepancy between the parts diagram and the repair manual. I ordered 2 of the rubber boots that go on the mounting shaft but the manual only shows one. If it does have 2 (and I think it should) I can’t get them both on. So if it uses both boots is there a trick to putting them on?
    Repair manual picture
    parts diagram... rubber boot that I am talking about is part #24
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jan 2005
    RI
    2,530
    there are supposed to be 2, but theyre a *Edited**Edited**Edited**Edited**Edited*. gotta keep on fighting with it. gotta get one side on, get the slide in there, then do the other side.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Lancaster, PA
    1,738
    yes there are 2 and they are a pain. I will see if I can help....
    make sure the grooves in the caliper for the boots to fit in are clean(I use a dremel with a smalll wire wheel). Install the inner one and then slide the shaft through (a little lube helps). push the shaft far enough to expose the groove for the outer boot. Install boot and slide the shaft back in postion. It will take a couple of tries to get the hang of it. Maybe somone else has an easier way, but thats the best I got.
    Good Luck!!!
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Nov 2002
    Kirkville, NY
    3,831
    ok, I will give it a try again. The shaft and boots are new so I would think it would be easier but of course not. Then again I did end up drilling out the old (stripped) shaft...
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Nov 2002
    Kirkville, NY
    3,831
    Success! I put the boot in opposite the brake pads then greased up the shaft and slid it through passed the point it should sit. The worked the other boot over the shaft and worked it in. Now to see if my rebuild works…
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Lancaster, PA
    1,738
    Glad to hear that!!!
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    and many more!!!
    Blue Line Graphics
    Apr 2006
    Crestview, Florida
    2,429
    I gave up after tearing two of those little $#%^ things up!
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by Erics350x View Post
    I tell ya grease is the key. I was able to get in installed in only a few minutes, both times (put in backwards the first time ). It is a part that should be greased anyways.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
