need help with rough idleing 185s
my buddies 185s was running rough barely idleing and flooding the engine. took the carb off and cleaned it all up and all the jets. looked over the carb boots and air box and everything is fine. now it idles really high and just seems like it won't stop revving up. it only starts to idle better when you put the choke on, but you can't ride it with the choke on because it just starts to spit an sputter and run like crap. what could cause this? could the float bowls be off or something else?
1986 Kawasaki KXT 250 tecate
ported, FMF pipe, DG silencer, boysen stage II reeds, 39mm keihin PWK, T4 thumb throttle and front master
