Thread: decompression cable on YTM200
    Jan 2008
    NJ
    5
    I found a decompression cable loose zip tied to my frame. where is it supposed to run to? is there a handlebar mount or something so i can reconnect it? thanks
    Dec 2005
    Wisconsin
    1,141
    No it goes to the cylinder head, (there's a lever that pushes on the exhaust valve). The other end of the cable goes to the back side of the recoil starter. There is a mechanism in the recoil that pulls the cable when you start it. Often times they wear out and don't work like they should. You don't really need it but it helps.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Jan 2008
    NJ
    5
    oooo ok now all i have it a cylinder-like fitting on the end like a throttle cable is that all i should have or am i missing pieces?
    1983 YTM200K
    1985 Honda 250sx R.I.P.
    Dec 2005
    Wisconsin
    1,141
    That's all you should have up by the cylinder head I believe. Look at the valve cover for the exhaust side, there should be an arm that the cable end fits into.
    1985 Honda 200x...
