I'd like to use a stroker kit from powroll. But unfortunatly i don't have the money, and after reading some reviews on here i don't think its for me. The guy i read who did his said it ended up being a stupid amount over what the price on the site said. (due to replacment parts or something they said he needed i think). the crf 230, the 200x and the cb 125 are all "basically" the same motor aside from stroke and bore. The cb is 8.3 mm shorter stroke then the 200x, the 200x is 8.4 shorter than the crf 230. The cb has a smaller bore, and the 200x and the crf are close (within a couple mm). If im thinking right, the only parts i should have to machine are the bushing peices that relocate the crank pin in the crank. The rest of the motor should be stock aside from the shorter cb125 rod. 8mm shorter rod, 8 mm offset crank pin, nothing should change as far as the rest of the motor correct?
atc rider-nah ive got an 84..I'm just too poor to spring for the stroker kit from powroll...
84' 200x wiseco 12:1, 30mm mikuni, k&n filter, powroll cam, bassani exhaust, 6 speed trans, running on E85
