Weak spark 84 big red & 200x
My 84 br has been running great but today when my friend was riding it, it just died on him. Had compression, but wouldn't start. I thought it was eletrical because I had just taken the battery out and put it into the warrior because that is being traded on sat.(ill tell more about this and the 200x below.) So I took the battery in the Warrior, put it in the br, the br started and ran great. Br rode home, went to drive it some more, it acted like it ran good for a few seconds then acted like it was low on power and was sputtering a little bit. I checked compression with my thumb, felt good but the spark was yellow and weak. Now it won't spark good(yellow, sometimes only first pull) I think it might be the coil but I am unsure.
Now to the 200x. I am trading my warrior for a 97 mxz 670 and a first gen 200x. Now from what the guy says, the 200x has close to the same problem, but will run good, start easy, other times won't start. He has an extra front fender, triple trees, and a motor with no cylinder. What do you guys think?
Thanks
current rides
84 200x - being rebuilt-supertrapp exhaust, uni air filter, hopefully a 10.5 to 1 piston
84 big red - cobra exhaust, custom head lights
83 185s - 200e engine, cobra exhaust
82 yz 60 - engine is out supposedly needs piston and rings
