lighten flywheels. and whos had one done r they good or bad.
Some people like em and some don't.. they say motors tend to stall at low RPM's but once you git used to it... you will like the EXTRA Pull ..
"07" DR650 Suzuki Dual Sport
dito, www.procycle.com will do this for 55$, Well thats a Z400 flywheel.
1987 Honda 200X 90% way through frame up.
1987 CR500R Motor, Soon to be a 540 ATC motor
1986 250R frame, For now
2008 Honda 700XX
2004 KFX700 Torque monster!
2011 Can-Am Commander 1000X
Looking for misc Liquid R parts
thanks guys i want alittle more top end speed. will it be good for dunes?
perfect for the dunes just not as easy to ride in slower 1st and 2nd gear trails that are tight.
I Lighten em also ... CNC Turned .. 35 bucs shipped Anywhere in the u.s.
2008 Honda 700XX
i want it done. i don't do tight wood trail its really open trail. and races we are moving to oklahoma, and im going to little sahara alot.
So can someone, maybe one of you guy's who lighten flywheels explain what material is removed. From the front side, back side, outside diameter, or all those surfaces? How do you know when to stop?
YTM-200, Wheeling machine!!!
1985 Honda 200x...
...Just a simple mild 200x
same here i want to know who does it
i have fixtures for most motors... the material that is turned off is just to the bottom of the balancing holes. "about .08" per side.. it's not alot of weight but the spinning mass is much lighter... i don't "face" them no-more because it makes them too weak on the outside near the rivets...
I Found a Pic ..............
