Well I dont exactly know what happened or why but its running perfect again. The head gasket had a little oil around it last night, now today there was not a drop of oil or coolant anywhere. Also no weird noises internally or anything to that degree. The cutting out problem was the carb. The little 8mm bolt holding on the throttle lever was slightly loose and somehow caused it to run like crap. So I put I repositioned the cam just like before with the 170 main and all is good, but the jetting could use dialed in some more. Well thanks for all the help, luckily it wasnt anything major any nothing got destroyed![]()
