Results 1 to 15 of 26
Thread: Finished my plow
    Apr 2008
    Manitoba Canada
    106
    Finished my plow
    Here are some pics of the plow I built for my Big Red. The plow is mounted on the same brackets for the foot protector bars I built. The brackets are mounted to the same mounting holes as the foot pegs. I take out one bolt from the bars (front motor mount bolt), slide them out, drive over the plow, slide the pivot rod in place and pin it, hook up the winch, and push.
    Seems to work well, obviously have not tried it in snow yet, but pushed some gravel and stuff around. Ran into a couple of curbs and stuff to see if the blade folded ok, and it does after adding another spring. Nothing broke after quite a bit of abuse. Steers heavy with the blade up, but with it down it steers easily.
    The frame is 1" square tube and various other steel for bracing and such. The blade is a section out of a hot water heater tank with some 1/4" bolted on as scraper blade. I made the "pads" (the concave pads that ride on the ground) out of 1/4" plate that I pressed into a concave shape in the 20ton shop press. The blade angles left and right by pulling a pin.
    I'll see what kind of traction I get out of the tires on snow, but might add some weight to the hitch if needed.
    1985 Honda Big Red 250ES
    27x12-10 Mud Bug rear tires on ITP aluminum rims
    27x10-12 Mudlite on front
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Looks great for 6 inches of powder!!!!
    You should stud and chain the rear tires for maximum traction.
    Mar 2005
    overton, PA
    5,257
    definitly cool good luck and kepe us posted when the white stuff flies
    I love trikes with plows. Maybe I should put on on my tecate-
    Dec 2005
    Wisconsin
    1,141
    I like it! ...and cool it's got a winch to raise it! Nice! Just hope the front rack is strong enough when you lift the plow full of snow.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Aug 2004
    Nampa, Idaho
    1,245
    I like to build one for my 200. We normally don't get more than a few inches at one time out here.
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    2000 Ford Explorer Sport
    Apr 2008
    Manitoba Canada
    106
    Quote Originally Posted by WIkid500 View Post
    I think the rack will be fine
    Apr 2008
    Manitoba Canada
    106
    Quote Originally Posted by firehart View Post
    Go for it. Even somthing more simple would work well, a little narrower without the angle and folding features. Not really hard to build. Hardest part was making the frame brackets that were dual purpose.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by 01ps View Post
    CENTRAL NY
    1,709
    My brother has one on his red, and it plows great! He does his driveway and half his front yard. He uses v bar chains in the rear and a had full of studs in the center rib of the front tire. Befor the chains he used a 40 pound bag of pellets on the rear rack. Just keep an eye on your front tire pressure with the extra weight of the plow, when my brother bought his the fork legs had about 3/8 of an inch wore down on the top of the fork legs by the dust seals from low tire pressure and the nobbies rubbing on the legs.
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    I have a cycle country plow on my red and love it add 80# of sand bags on the back rack and it will plow through about 10 to 12 inches of snow no problem
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Feb 2008
    Pennsylvania
    2,306
    I got a cycle country off ebay for mine acouple months back and cant wait to use it this winter.
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    Apr 2008
    Manitoba Canada
    106
    Quote Originally Posted by freaksfix View Post
    I am hoping to not have to use chains. I think adding a bunch of weight will work fine, and I am not exactly a featherweight myself
    Dec 2005
    Wisconsin
    1,141
    HAhah yep I think it will do just fine. lol
    1985 Honda 200x...
    Apr 2008
    Manitoba Canada
    106
    Quote Originally Posted by erectordale View Post
    That's good to hear. I pushed some loose gravel around, no lack of power. If I can get traction I should be good. I was thinking 80-100lbs weight would work fine.
