The conversation at work during a smoke break ended up on performance, like always.![]()
Anyhow, my co-worker use to race go karts and all the engines where certified to a standard. So every little adjustment and quirk made a big difference.
He brought up that he use to "index" the spark plug so that the electrode arm does not interfere with the natural air flow in and out of the combustion chamber.
Point being, he would use washers to make sure that when the plug is tightened, it would be in the position he wanted. Arm of the electrode providing as minimal resistance to the intake and exhaust flow as possible.
Not sure if this helps,
but according to him, it really helps with much easier starting, smoother running and overall economy with a small amount of improvement in the engines responce to throttle.
Just wondering if it would be worth the effort![]()
to get a rebuild has too much crankcase pressure and wont shift need piston, rings
