Results 1 to 11 of 11
Thread: 84 250r carb size?
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    84 250r carb size?
    ok i have a question. i am changing my carb. i would like to know if the 38mm pj or 38 pwk keihn carb is to big for a basically stock 250r. i will be getting an exhaust, but not at this time. also the piston is 3 sizes over. also i am running a k&n filter and will most likely get a dg pipe (since they are easier to find)
    please let me know. thanks
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
    May 2007
    Coshocton, Ohio
    1,815
    A 38 is too big for a stock engine even with a pipe and reeds. I wouldn't go any bigger than a 36 and a 34 would probably be ideal. The bigger the carb the worse the low end performance unless you have the cc's to handle it.
    Appalachian American Racing
    the home of
    sbjones73's Avatar
    wisconsin
    414
    ok, i actually have a 85 250r 34mm carb (round slide). is this a good upgrade or should i look for a pj (flat slide) carb.
    i would like to get the best i can with what i can afford. will the 85 carb "wake " up the basically stock 84 good or not?
    thanks for all of the help!!!!!!!!!!!!
    84 250r gone,
    springville, PA
    6,185
    using the liquid cooled 250r carb is one way that has been said to get more performance out of the air fooler. Jet it, slap it on, and see how it does.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    sbjones73's Avatar
    wisconsin
    414
    do you guys know of any site that has the id numbers of the carbs and tells what they are.like pe or pj carbs.
    i have run into so many people that do not know how to measure there carb and i don't want to get a carb that is to big for my engine.
    i have decided to use the pe carb from the 85 that i have and keep looking for a pj or pwk striker carb.
    84 250r gone,
    springville, PA
    6,185
    if you can find a number on a kehin Carb, then the kehin website can assist you from there
    http://www.keihin-us.com/am/
    Nate
    R.I.P HRR
    Aug 2004
    Phoenix
    1,226
    Quote Originally Posted by sbjones73 View Post
    It's not hard to figure out what carb is what. A PE series is a roundslide carb. and a PJ is a flatslide.
    4 Strokes are NOT the wave of the future!
    sbjones73's Avatar
    wisconsin
    414
    3razors. i know how to look at a carb and tell if it is a pe or pj. what i meant was. is that pe a 30 34 36? pj 34 36 38? that is what i meant. i only ask this becuase many don't know. and i don't want to waste my money on a carb that is too big for my trike.
    sorry if i was not clear on this.
    84 250r gone,
    oregon
    78
    from what i have seen the serial # on the side of carb usually has a 2 digit # followed by some letters. this is the size in mm of the carb. like mine is PE 30xxxx
    i'm glad i read this though as i am looking for something a bit larger for my 84 R and wasn't sure if the 85-86 carbs would work. how bout a trx 250r carb? i think stock carb on them was a 34mm Keihin.
    Dec 2006
    W. PA
    463
    I put the '85 R carb on my fooler, haven't had a lot of seat time on since the upgrade, but so far I like it. Dropped into place with all the stock parts.
    http://www.3wheelerworldforums.com/s...ad.php?t=87741
    1984 250r
    heap of 200x
    POS motorcraft?
    Quote Originally Posted by JAGSFOLIFE
    THOSE F^@&ERS ARE DEATH TRAPS, BUT SO BAD @$$...
    Quote Originally Posted by yamaha gp
    trikes... DANGEROUS MOTHER F***S. BUDDY LOST HALF HIS SPLEEN AND A LIVER BECAUSE OF ONE OF THEN. HAHAH
    Quote Originally Posted by smackdab
    We decided those cute little 90 and 110 Honda 3 wheelers were what we all needed. Although our experience with those little SOB's is a story for another day, I will tell you that the Caro Community Hospital got new waiting room furniture due to those cute little devils.
    sbjones73's Avatar
    wisconsin
    414
    to cheap, i read your write up and that is whay i was thinking of going witht eh 85 carb. thanks for the information.
    the trx carb from what i can tell is a 34mm carb, but just be sure that it is stock. alot of people put bigger carbs on them. that is why i asked about the numbers for id'ing the size of the them
    84 250r gone,
