Thread: 86 250r with Selvy pipe, got questions
    Feb 2008
    Orange County California
    726
    I asked this question in a different thread, and am reposting it here to be more appropriate. here is where we left off. Any input would br greatly appreciated. Thank you in advance.
    Quote Originally Posted by NINJA View Post
    That is an awsome pipe. But without the high HP needed, the pipe is useless.
    That's very true, If that cylinder isn't ported for that pipe, it's kind of a waste. That is a friggin clean R, very nice, I love 86s![/QUOTE]
    Quote Originally Posted by Autophysn View Post
    Thanks! The guy did say they did a piston to it about five years after he bought it from the dealer. I have yet to fire her up. Bought it in a not running condition. Previous owner swears it was in good running condition and all he did was store it, so carb must be gunked up. However the throttle cable operates smoothly, so it must not be too bad.
    Oh one more thing, if that's true about the piston, so when my top end goes, sure it will sooner or later, will this pipe work with a 310 big bore kit?
    Are there many mods needed to do a big bore kit? I would assume if you had to do it, why not go big?
    1986 ATC250r
    1984 ATC70
    Aug 2007
    Moab, UT
    1,807
    You could go with a 270 kit and get it ported by ESR, then that pipe would be working for you.
    Aug 2004
    Phoenix
    1,229
    It just depends on how big you want to go, generally the bigger the more $$$, all the way up to a sabertooth 500cc cylinder.
    I would personally get acustomed to the 250cc cylinder power you have now before wanting more. And bigger isn't always better...I've seen alot of fine tuned stock cylinder 250R's walk all over 310 ect kits. It's all in the setup and tuning.
    Remove all the warning label and let nature take its course
    Feb 2008
    726
    Pulled the carb today, looked totally clean, for sitting for ten yrs. Put it back on and threw in some fresh fuel. 91/golden spectro at 32:1.
    MY GOD, THIS BIKE IS A BEAST!!!!!!!!!!!!!!!!!!
    I could not believe the power! It wanted to come from underneath me in fourth gear. I have rode 250r's before, but not like this. This thing rocks!
    Can't wait to get it in the dunes. I can see now what you guys where trying to say about getting use to it first.
    But no way was I prepared for it to start on the first kick, and just scream!
    It smoked a bit at first, but that was it, more like all the goo from the previous owner running 20:1.
    only problems where the brakes where completely gone, suppose the seals have gone bad in the cylinders, and the kill switch did not work. Have to dump the clutch to kill it. Found it funny the idle was set so low, it would just kill the engine.
    Sorry, just way excited, your thoughts?
    1986 ATC250r
    1984 ATC70
    Aug 2004
    Phoenix
    1,229
    From the pics and description sounds like you have a good one. Most of the 250R's out there have been hacked on pretty good, so now you know what one is supposed to run like. Don't worry about a lil smoke on startup..it's a good thing.
    Sep 2007
    oregon
    2,292
    lucky.....
