i was jumping it and lost third gear and the top end has been noisy .
It was pretty easy getting the engine out of the frame but the top end was
pretty stubborn. Then i started to get a lil nervous..... Id never done this before
i split the case with a small chisel and the "worm gear" and the smaller of the two gearsets came out with a shift fork attached. Afterplaying with them figuring out how they went together i inspected all of my gears. They were fine
so i am asuming i have a bent shift fork. As soon as i can spare some cash i need to buy a manual and a gasket set. Also i plan on doing the crank bearing if i can find one at a reasonable price money is tight and it sucks. A new piston is like $130 not to mention to have the cylinder bored.
to get a rebuild has too much crankcase pressure and wont shift need piston, rings
to lightly tap the case here and there and it just comes right apart.
