Page 123 of 123 FirstFirst ... 23 73 113 121 122 123
Results 1,831 to 1,841 of 1841
Thread: What did you do with your trike(s) today?
  1. #1831
    Jul 2012
    Seattle, Washington
    1,543
    I used a Minimoto oil cooler mount from webike. I think tboltusa.com sells their own parts, there may be similar products on eBay too?
    https://japan.webike.net/ps/Minimoto...r&p.p=2&p.sk=0
  2. #1832
    Nov 2015
    Davenport iowa
    1,144
    Fired up a Nicholson 90 today, was a barn find, put in a new timing chain and honed the cylinder, runs good dosent smoke .. getting ready to flip it..Click image for larger version.
  3. #1833
    Jul 2012
    Seattle, Washington
    1,543
    I mounted my tires on the wheels and got this one back on 3. I’m waiting on a cam sprocket to finish the engine. It’s starting to look like a 3 wheeler again.
ID:	251055Click image for larger version.
ID:	251056Click image for larger version.
ID:	251057Click image for larger version.
ID:	251058Click image for larger version.
  4. #1834
    Nov 2015
    Davenport iowa
    1,144
    Finished up on one of our 185s getting it ready for resale..
  5. #1835
    Jun 2013
    Oceanside, CA.
    613
    Quote Originally Posted by 3 Wheel Drive View Post
    Starting to look real nice....need to ask a couple questions, you made a posting in the classified section asking for aluminum wheels, I see you now have a four bolt front wheel and three bolt rear wheels, are they stock 7" or 8" and from where? Also in a previous post you show an engine stand where'd you get it?
    "HJ" Click image for larger version.
ID:	251075Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
  6. #1836
    Jul 2012
    Seattle, Washington
    1,543
    The wheels are 3 bolt 7” from Xowner, and the engine stand is from webike.
  7. #1837
    Jun 2013
    Oceanside, CA.
    613
    Thanks for the info I have 2 sets of "Xowner" wheels, there quality is great. My first view of your above posting looked like 4 bolt aluminum center hub, now its clearly a three bolt. Who made or sells them?
  8. #1838
    Jul 2012
    Seattle, Washington
    1,543
    I got the front hub on eBay. Does anyone know if there are any stock atc 70 rear aluminum hubs for sale online?
    https://rover.ebay.com/rover/0/0/0?m...2F122859319760
  9. #1839
    Jun 2013
    Oceanside, CA.
    613
    Thanks for the info. Looked at the ebay listing which states the bolt circle diameter to be 3/110 and I messaged to ask if correct are did they make a mistake in the listing BC. Did your hub bolt up to the new wheels without re-drilling a new bolt pattern? If so than the hub is a BC 3/100 as all early Honda hubs were.
  10. #1840
    Jul 2012
    Seattle, Washington
    1,543
    My hub bolted up to the aluminum wheel just fine. No extra drilling required.
  11. #1841
    Jun 2009
    Leander TX
    2,217
    Today was fix the nagging 350X problems at the last minute before heading to the dunes day:
    - clean and lube the squeaking shock top mount - dammit that was annoying
    - tear apart kick lever and clean and lube the detent spring and ball and the pivot so it won't lock in the closed position when I need to start it in the middle of the dunes
