Yesterday I took my 200m out and pulled my brother and his friend around the backyard on sleds. Today I'm going to try to make a Youtube vid with my trike if a buddy comes over.
Rides:
1985 250sx
1982 ATC185s
1984 200es
Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
"Wear Limits Are Just A Suggestion"
Well i picked up this little 350x 2 weeks ago today, it came with over 1250.00 in motor/chassis bearing receipts so i called the shop that built it and he said they had over 1800 in it and the price was less than the motor work. It wasn't really painted the way i wanted it to be so last night i repainted everything that was baby blue but the taillight bracket, i put some decent z400 stock wheels/tires on the rear, white maier plastics, changed the oil, replaced a leaking fuel line, tightened up the rear end, polished the upper motor fins to take away from the drab black, and tried to clean it up a little.
The frame was pc'd but its not super good (ended up kind of dull), as well as the front and rear hubs, headlight guard, foot pegs and rear brake lever. It's a nice super tight machine and i have no idea whats in the motor but the whole bottom end was redone, crank was machined, bored with a new piston, all new valves, oem timing chain, oil pump, it just goes on and on. The best part is this thing flat out flies.
My only other plans are to buy a junk or plastic tank because the one on it is dent free, and i'm gonna take off the headlight because its a lot cleaner than most aside from the one lens. Oh yeah and i plan to ride this one as much as i can. We're going out around lunch time today, TC...
86 350X
85 350X daily rider
LC 250R
85 T3
86 T3 roller
85 250sx beater
mailed my frame away....
Completely disassembled my 73 Atc 70. Getting it ready to restore it and having it ready for Sandpuppies ride in August at Rose City. It was the easiest thing to tear down. Not one nut or bolt broke.
85 Big Red
83 Big Red
84 125m
85 TRX 125
73 ATC 70
Finally got my 84 200S that I bought a while back running today. Cleaned and redcoated the gas tank. New Carb. New Fuel lines. New sparkplug. New airfilter. New (used from ebay) factory exhaust.
She fired up on the 3rd pull and runs great! Now to change the oil (probably should have done that first) and get it cleaned up a bit.
today i fell trough the pond. didnt realise the damn broke and there was 6 feet of air under the ice and then the water
I moved all of mine into a line in the backyard. I think I'm going to take the 125m down to the DMV after work on Monday and see if I can get a title for it.
Current rides
83 185s
06 Rancher ES
95 Ford F150 4X4
2000 Ford Explorer Sport
225dx took it down to river and putted around. still having problems with lack of power dont know why but was still fun.
Today I had my 200m out for a run around the yard. I new it was running rich so I decided to drop the needle on the slide one notch, then I realized it was down as far as it would go.
Rides:
1985 250sx
1982 ATC185s
1984 200es
Started clutch work on the Honda
Make a home made flywheel puller for my trimoto 125 lol.
Did a little riding at a new place
Climbing
Hill is bigger than it looks and fairly steep. Just right to have fun on.
-BFC
'86 250R
Attached the Trail Tech Vapor to the 225drs, took about an hour to fit, covers rpm, speed, engine temp, shift lights, etc.
