rode my bigred for a good 3 hours figured she hasnt been run in a while. some trails, hills, swamp and then to the local car wash to clean her off in that order lol.
85 1/2 Tri-Z
85 350X
85 250ES
R&R fork seals on the #2 AutoX.
Located and purchased Front Hub and Brake caliper for a thumper build.
I moved my 200es(until I can get her a new tank), my 200s(she needs a ring job and clutch work), and my Suzi 185(she's the skank of the bunch) out of my shop to a friend's huge storage building to make room. I can now fit a Geo Metro in my shop without having to pull everything out!
Today I installed my rear axle as it was bent and I had it straightened, also changing my rear tires.
Derusted a 200x tank yesterday and will Kreem today. Rebuilt 200x brake master cylinder for the Nick.
took pictures of my new tecate for everyone to see. and then rode it for a few, wanting to see what it does in about a inch of snow. lol
2006 Yamaha Raptor 700
2004 Kawasaki KFX700 V Force
1985 Suzuki LT230GE(wifes toy)
1985 Honda ATC 70
1979 Honda ATC 70 (daughters toy)
played with my atc 70 that I bought. It bought it as non running. I adjusted the valves, cleaned the carb, checked the timing, and tightened the cam chain. Then I found out that the intake studs had a helicoil in it that was not doing its job. When you try to tighten the nut it pulls the stud out. Gotta fix that.
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
i made a mount for my 2in powermadd block riser for my trike
I started the 400x up twice yesterday, today just looked at em a few times!
1985 Honda Big Red 250es Swamp Edition
1985 Honda 350X/400X
http://s779.photobucket.com/albums/y...zyquadrider83/
http://community.webshots.com/user/mondexbruteforce
New clutch cable bracket fabbed and installed, clutch cable and decomp. cables installed and adjusted on GenII Nick
Rode my atc70 on the road and started to make a small trials course for it
Worked on a trx200sx. ugh pain.
admired my 350x![]()
85 350x
84 tecate 3
84 ATC70 http://www.3wheelerworld.com/showthr...C70-Buildup!!!
My youtube! http://www.youtube.com/user/vortex812
Over the last week or so, I finally finished tearing my 350X beater apart and sent the frame off to TPC for gussetting.
While that's out for work, I'm cleaning up the major sub-assemblies. I started with the forks. I took them apart and bead blasted the tripples and the fork lowers. This is my first major use of my bead blaster and it's awesome!
One of the fork tubes is bent so it goes to the shop for tweaking this week.
And, the Loncin 200X got a longer shifter. The shift shaft is in the same location as a Honda 200x engine but the shaft is shorter so a 200x shifter won't clear the stator cover. The Loncin shifter was about 2 inches too short - it was a pain to ride with - I have big feet. I spent about 2 hours looking and shifter pictures on eBay and found a heel & toe shifter from a Chinese quad that looked like it would work. Cut off the heel part and it works fine.
Got my cases to match up finnaly! now i got to wait till friday to re assemble it completely
The '82 hub, axle, disc, and caliper came in today. Guess all the parts are here to make a Fat Tire Thumper
i found some other parts to that caliper Rick ill send them out tomorrow glad to see you got them.
