Results 1 to 3 of 3
Thread: bolt in bottom tripple snapped Tri-Z
    Sep 2008
    AU
    48
    hi guys, i wrenched a little to hard on one of the bolts that tightens the bottom tripple clamp to the fork. can it still be ridden safely over jumps ect?
    otherwise is there any way to get it out? its all the way in there and it snapped in half..
    thanks for clicking
    85 250R
    85 Tri-Z
    80 110
    Oregon
    2,471
    Try a Easy out, should be able to find it at your local auto parts store ( get the kit )
    Jun 2006
    Illinois
    491
    Yes, I agree. Try an easy out. The triple clamp/fork bolts are only torqued to something like 17ft. lbs.. I would definitely remove the cracked bolt and replace it with a new one though. Use a torque wrench, even if you have to borrow one.
