so what do i need to put in it it a twist cap om the side?? ok this is what is going on with the trike i can crank it and it revs up fine . i get on it and put it in first grear and it will rid kinda slow and it starts to pick up speed .when i put it in to 2nd gear it starts to bogg down and wont hardly run .so i put it in 1st and still the same thing ?? do you thing im not getting any gas or not mixxing my oil/gas mix right ? there is nothing in that spot where the cap is that yall said is for trans oil can that be what it is ? also i want to get rid od the oil pump what can i do ? what do i need to do with the hoses
